600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
Transform F4i into a Naked Bike
Old Apr 23, 2008 | 09:43 PM
andrewsi's Avatar
Default Transform F4i into a Naked Bike
I recently laid down my F4i and scratched up the right fairing. I had sliders, so it wasn't that bad, but I want to strip off the fairings and convert my F4i into essentially a Naked Bike. I have always liked naked bikes and now I kinda have a reason to convert mine. There are a few main things I would like to achieve with this which I am hoping the CBR forum community to help me with.
1. Replace front cowl with just small round dual headlights and maybe a little windscreen, kind of what is on some Monsters (Duc).
2. Clean up the internals and wiring that will be exposed after the fairings are removed
3. Remove/Replace rear seat cowl with a single seat (cut off in back look) or find a reduced cowl like the GP bikes have
-I would probably have to throw a new rear light on the back, but I would like to use my existing OEM part
I am in college and poor, so think of plans on a budget basis.
Cheers!
AJ
PS I am studying to be a Mech Engineer (Senior) and have worked on my bike a fair amount. So bring on the technical jargon.
Old May 7, 2008 | 07:40 PM
cbrrrrrrrr's Avatar
Default RE: Transform F4i into a Naked Bike
i dont know if it would cause loss of structural integrity but you could start drilling holes in the frame and rerouting wires/hoses through it. you could probably snag a headlight and mini windscreen off a sv650 or something. you'd also want to clean up the gauges but i dont know how you would do that. buying a special streetfighter tail fairing would probabbly be expensive, so i would maybe learn how to work fiberglass ha.
this guy did a pretty radical thing with the gauges
http://www.sv-portal.com/forums/atta...p;d=1156452724
go for it, it could be badass!
Old May 9, 2008 | 10:06 PM
andrewsi's Avatar
Can't drill holes into the frame. This drastically weakens it. frames are designed with a low factory of safety and shouldn't be tampered with.
In regards to my project. I have worked with carbon fiber and resin, so I theoretically could make a rear cowl, but don't really want to (Too much work). I plan on getting new gauges and a custom wind screen. Wiring is the major issue and water proofing is the major issue I forsee. Any suggestions?
Old May 14, 2008 | 01:24 PM
ta8218's Avatar
re-route all wires into one big clump and wrap it with something and send it backwards. nice clean look.
Old Aug 6, 2008 | 07:10 PM
jojackson's Avatar
I took out the majority of my wiring harness after my bike was wrecked. I did away with everything, but my blinker, hi/lo beam, and ignition wires. i kept my speedo/tacho wires exposed for when i get the money to buy veypor gauges. i have an F3, though. a bit simpler than the F4i i'll assume.
jasonchristopher
Nov 18, 2012 01:52 AM
andrewsi
Jun 15, 2008 01:21 PM
andrewsi
Apr 26, 2008 11:41 AM
nickmac120
Feb 5, 2008 12:43 PM
Destinmatt
Feb 17, 2006 12:54 AM
