600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
Test pipe..
Old Sep 16, 2007 | 09:06 PM
Fendogg's Avatar
Default Test pipe..
If I was to fab up a short downturned testpipe coming from the header collector, that I could easily swap back to the streetpipe/silencer, would that negatively affect performance without some tuning?
I'm sure it would beF1 car loud.
Fendogg's Avatar
Default RE: Test pipe..
Oh yea its an 02' F4i
Old Sep 16, 2007 | 09:20 PM
doncollins's Avatar
Retired Administrator
Yes it will, going from exhaust to no exhaust ... just a pipe will change the fuel to air ratio and not give you what you're looking for. I'm not an engine expert, so you may need better advice here, but it could damage or at least shorten the life of your engine. I mean your plugs are going to wear out faster and your engine will build up carbon faster screwing up the valves and so on.... like I said, not an expert, but from my limit knowledge, I wouldn't do it unless you have a PCIII and a map for each setup.
Old Sep 16, 2007 | 10:10 PM
Hatebreed's Avatar
yah, it would be great if you had power commander to change map but if you cant tune it for the new downpipe i wouldnt do it...
Old Sep 17, 2007 | 09:18 AM
Fendogg's Avatar
Ok well, I'll try getting a Power Commander and tune it. I'm assuming no backpressure from an exhaust would lean it out?
Old Sep 17, 2007 | 06:35 PM
doncollins's Avatar
Any exhaust change will mess with the fuel/air ratio, one as extreme as no an open pipe needs to be mapped.
mcguire6799
May 28, 2011 11:16 PM
danl23880
Nov 17, 2010 11:59 PM
TheX
Dec 28, 2008 11:00 PM
Woody6799
Mar 16, 2008 05:36 PM
Jon Boy
Nov 5, 2006 01:26 PM
