pipe guard with aftermarket pipe
Old Nov 10, 2010 | 04:46 PM
danl23880's Avatar
Default pipe guard with aftermarket pipe
i have an 06 cbr600 and i just purchased the stock pipe protector guard that hides the pipe on the bike. This attaches at the top of the footpeg and then there is another screw int he middle on the plastic piece that attached to the stock pipe. Hense i have an aftermarket pipe how do you guys rig this to make it work?
http://www.motosport.com/motorcycle/...&groupId=52829
I am talking about part 10
the middle screw (part31) i have nothing to attach to because the aftermarket pipe i have. How do you rig this
Old Nov 12, 2010 | 11:25 AM
danl23880's Avatar
anyone know what i am talking about or have any input?
Anything helps
Old Nov 12, 2010 | 12:08 PM
R Dub's Avatar
October 2011 ROTM
Sorry bud but I don't think I can be off too much help here. All bike I see with an aftermarket pipe just take the shield off. I think the bike looks better with it on so if I do go with a aftermarket pipe I wold want it on there as well. The only thing i can think off is drill a hole in the bike and tap it and screw it into the pipe or weld a nut onto the pipe and screw it into the nut that you just welded.
Old Nov 12, 2010 | 01:01 PM
N8 Dawg's Avatar
You will need the heat shield if you dont have it (part 5) thats where the middle bolt attaches to.
Old Nov 13, 2010 | 11:00 AM
danl23880's Avatar
alright well i appreciate the help guys. R Dub you have helped me on the majority of my posts and i appreciate that as well.
I can mount the bottom screw so it holds a little. I was going to take heat shield or the dei reflect heat shield and use this. http://www.motosport.com/motorcycle/...4in/?id=110228
Then for the middle bolt I will rig something up.
Thansk for the help though i will let you no how it goes.
Old Nov 14, 2010 | 01:45 PM
cwmc29's Avatar
I put on a aftermarket Jardine pipe, then put a carbon fiber heat shield cover on. You have to put on the original heat shield (inner) on and then afix the heat shield (outer) to it. It makes the bike look finished.
Old Nov 14, 2010 | 06:44 PM
danl23880's Avatar
I appreciate it man. Will the stock heat shield work with the aftermarket pipe. Will it mount right up or will i need to do modifications. I hate to ask but could you explain or take some photos. I appreciate the help.
Thanks for the response.
Old Nov 14, 2010 | 08:49 PM
cwmc29's Avatar
The inner heat shield should screw right on with the original bolts. After that is secured, you then put on the outer heat shield which screws into the inner shield. I'll get a couple pics for you later.
Old Nov 14, 2010 | 09:09 PM
danl23880's Avatar
Thanks i am still lost lol. It dont take much. If you could post some pic it would truly be appreciated. Thanks alot man.
Old Nov 15, 2010 | 11:23 AM
Quick6's Avatar
My Yosh came with a heatshield ?? looks factory up until you get to the tail
