600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
how to knock out baffle???
Old Jun 25, 2007 | 12:30 PM
schultzy's Avatar
Default how to knock out baffle???
i have an 06 f4i with factory pipe.ill be buying a new pipe one day but i want it louder. whats the best way to knock out the baffle in my stock pipe so it will be louder. my friend bought a f4 with this done and it dont sound too bad.i was just going to stick something down in there and start knocking but i wasnt sure about getting the baffle wedged sideways and restricting the airflow
any suggestions..........
Old Jul 14, 2007 | 01:17 AM
Built B16a's Avatar
Default RE: how to knock out baffle???
i was given a scorpion muffler for free.. and didn't have a pipe that fit.. so i essencially cut the OEM muffler, and welded mine in place. while i had it off, i was thinking the same thing, punch out the baffle.. but it was ****ing STOUT! i tired hitting it with a punch and a hammer, and i tried hitting the head of a hammer with another hammer, and i coudln't get it to budge.
but it was unlike catalitic coverter material. it was steel. so my guess is, if you want to remove the baffle.. your going to have to chop it off, and replace that section with another pipe that doesn't have that baffle in it.
just to clarify.. im think im refering to the resonator. its between the slip on, and the muffler.. baffles are usually used inside the muffler.
anyways.. here's a pic of my setup. you can see the bulgeunder the foot peg where the resonator is located.
Old Aug 11, 2007 | 11:01 PM
Sand.Man's Avatar
Drill it out (the stuff in the muffler)
Geta long 1/4 inch drill bit and a good drill and go to town, put a few holes in the baffles and the sound will be changed quite a bit!
Dont worry about the metal shavings, they will either get blown out or just hang out in the pipe, they wont go back up the pipe.
Old Sep 20, 2007 | 12:10 PM
JDM GC8's Avatar
Im confused what does the baffle look like?
Fuegoblade
Feb 16, 2011 06:45 PM
sofakingtore420
Aug 12, 2007 01:32 PM
2002F4!
Jun 27, 2007 05:28 PM
blkmrkt_lung
Mar 4, 2007 06:17 PM
jhcole100
Oct 3, 2006 07:41 PM
