can baffle
Old Oct 3, 2006 | 06:26 PM
jhcole100's Avatar
Default can baffle
Can someone explain how to drill out the baffle of the stock can? How does it sound? Loud or what? Thanks
Old Oct 3, 2006 | 07:41 PM
baxsom's Avatar
Default RE: can baffle
you get a 18" extension attach it to a 1" or larger metal drill bit and push it into the back of the pipe (each side) until you feel it hit the baffle
then drill through
i did it with the bike running so the exhaust would push the metal shavings out the back
as they come loose
it definetly makes a difference in sound because when i had my stock drilled out exhaust dynoed for a baseline the operator told me that he thought it was a stock pipe but it sounded different
there is a sound clip on http://hooliganbiketech.dynup.net/ho...frameindex.htm of the drilled out pipe as well as many other clips
sk8rat
Apr 8, 2008 06:40 AM
Midnight1kRR
Mar 28, 2008 08:17 AM
sofakingtore420
Aug 12, 2007 01:32 PM
LEATHERFACE
Mar 16, 2007 10:33 AM
blkmrkt_lung
Mar 4, 2007 06:17 PM
