600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
K&N air filter question
Old Aug 14, 2007 | 11:10 AM
travisgarrison's Avatar
Default K&N air filter question
If I install the K&N air filter for my '99 F4 am I going to need to install a jet kit as well, or will it not mess up the fuel air mixture too much?
Old Aug 17, 2007 | 09:52 AM
Sand.Man's Avatar
Default RE: K&N air filter question
I've been told yes and no, I think if you stick with the "street" K&N filter and dont go with a race filter it should be okay... but you'll never know until you try.
Also, get the single big filter to replace the OEM one, dont get the 4 individual cone filters, then you will need rejetting I'm fairly sure.
Let me know if it messes yours up, then i know whether or not to get one :P
Old Aug 20, 2007 | 04:43 PM
bmg velocity's Avatar
If you put on a new filter system, I would recommend doing a jet kit upgrade. New systeme meaning anything radically makes your
bike take in more air, meaning making it run more lean.
Old Aug 24, 2007 | 07:57 PM
kallelsf2's Avatar
get the filter install it see how it runs some need rejeting some don't my f2 didn't my 929 didn't but some guys say theirs did....
Old Aug 24, 2007 | 08:00 PM
kallelsf2's Avatar
but then again my 929 is fuel injected so no jets hehe
Old Aug 27, 2007 | 05:00 PM
FLYIN HAWAIIAN's Avatar
Depending on where you ride. Altitude can play a big part. I have a full race exhaust with stock air fiter and did not need a jet kit. My bike was setup for sea level where it was running rich and now 6000ft above sea level, it runs perfect!
Old Aug 29, 2007 | 06:48 PM
kjohnson's Avatar
I wouldn't get a K&N.Carbed bikes make more power with paper and the stock airbox.
Old Aug 30, 2007 | 11:41 PM
Why would more airflow from the K&N filter cause less performance? I'm not totally a dunce, but I don't really understand the logic in that.
Old Aug 30, 2007 | 11:44 PM
Ok, so I installed the K&N filter, and there are no flat spots or hesitation. It's real smooth through the power band. I don't feel like there was a huge performance increase, but I suspect I might be running lean, because I have been having some temperature problems. in a week or two I am going to test the bike to see if it's running lean. If it is then I will rejet (I might do this eventually anyway.
I am at 500 feet also, so that may be why its not so lean that I'm having noticeable problems.
Old Aug 31, 2007 | 06:38 AM
cbr600fu's Avatar
I threwa K&N in my 2000 f4 a few months ago and love the way it runs now... my stock filter was pretty ugly though.Iimmediately noticed animprovement from 5k to 9k rpms.
I'm at sea level with no jetting.
