600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
Taillight fuse
Old Jul 11, 2010 | 09:34 PM
danl23880's Avatar
Default Taillight fuse
So all of the sudden my bike backlight is not working. When i hit the breaks it does not light up and the signals in the intergrated back tailight are not working. All front signals are working perfect along with headlight. I thought a herd a pop like a fuse blew but if that happened wouldnt the front not work. Is there a fuse just for the back taillight. Also i am a noob would these fuses be under the seat. What are your opinoins.
Thanks
Old Jul 12, 2010 | 10:54 AM
cbrjoker's Avatar
yea if the fuse poped the front turns wouldnt work and ur gauge cluster wouldnt either check under the throttle bar should b a hex screw and a lil plastic peace thats says fuse on it there should be like 4 or 5 fuses in that lil box under the plastic when u take it off
Old Jul 13, 2010 | 12:42 AM
danl23880's Avatar
I checked a fuse near the batter under the seat, there was only 1 fuse a 30 i believe the main fuse. this was fine. I looked at the left fairing where there were a few fuses there and nothing was popped. Where else are the fuses. Did you meen under the throttle or gass in your upper post.
Old Jul 21, 2010 | 01:12 PM
adrenalnjunky's Avatar
It's not a fuse issue if the front signals are still working.
something's probably gone all toasty in your integrated light - LED bulbs last for a long time, but the electronics that drive them can be pretty unreliable. The other issue is if there is a fuse inline with the integrated system - and it has blown, there's usually a good reason. Sticking in bigger rated fuses until it stops blowing is a good way to end up with a CBR flambe'.
adrenalnjunky
F2 For Sale / Trade / Wanted
May 10, 2011 02:07 PM
dmcb2120
Aug 2, 2009 02:32 AM
Joey_f4i
May 4, 2009 10:00 PM
Altephor
Apr 9, 2008 12:44 AM
ox.
May 26, 2006 12:13 AM
