Taillight fuse
So all of the sudden my bike backlight is not working. When i hit the breaks it does not light up and the signals in the intergrated back tailight are not working. All front signals are working perfect along with headlight. I thought a herd a pop like a fuse blew but if that happened wouldnt the front not work. Is there a fuse just for the back taillight. Also i am a noob would these fuses be under the seat. What are your opinoins.
Thanks |
yea if the fuse poped the front turns wouldnt work and ur gauge cluster wouldnt either check under the throttle bar should b a hex screw and a lil plastic peace thats says fuse on it there should be like 4 or 5 fuses in that lil box under the plastic when u take it off
I checked a fuse near the batter under the seat, there was only 1 fuse a 30 i believe the main fuse. this was fine. I looked at the left fairing where there were a few fuses there and nothing was popped. Where else are the fuses. Did you meen under the throttle or gass in your upper post.
It's not a fuse issue if the front signals are still working.
something's probably gone all toasty in your integrated light - LED bulbs last for a long time, but the electronics that drive them can be pretty unreliable. The other issue is if there is a fuse inline with the integrated system - and it has blown, there's usually a good reason. Sticking in bigger rated fuses until it stops blowing is a good way to end up with a CBR flambe'. |
