600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
Front sprocket
Old Apr 24, 2013 | 05:30 PM
Ashspike's Avatar
Default Front sprocket
Hi ive recently bought a new did chain n sprok kit to fit to my f4
My mate said about geting a reduced teeth front sprocket and will get more pull is this true and what size would be best tooth wise for my f4 ??cheers
Old Apr 24, 2013 | 05:57 PM
CorruptFile's Avatar
June 2013 ROTM
-1 is all you want to go. -1/+2 is a common sprocket setup.
Old Apr 25, 2013 | 08:40 AM
Ashspike's Avatar
Ok cool i see so -1 will give me better power/performance???
Old Apr 25, 2013 | 08:50 AM
June 2013 ROTM
It won't give you more power. Powerplant changes do that. With driveline changes, its give and take. You will gain some acceleration off the line, but lose top end speed. I am not a huge fan of just changing one component of the driveline, especially if it is older and needing replaced. Save/spend the extra $$$'s and get a new chain and rear sprocket while your down there. Keep in mind going JUST -1 in the front will mean you will have to compensate for the slack with your chain tension adjustment. Going -1/+2 'evens' it out a bit.
slightreturn
Apr 19, 2013 10:25 PM
aeroworks
Mar 16, 2006 11:57 AM
