F4i/RR body conversion
Sorry it took so long to reply, but as far as the speedo goes, you just follow the wiring diagrams between the two gauge clusters and match everything up. Although without the speedo-healer at 25-30mph your speedo will read 4 to 5mph.
The fairing stay brackets can be done in many ways, it just depends on how technical you want to get. You could even do something as simple as using bar stock.
The subframe is still the F2, I cut the back of it, bent the end up about 27 degrees, welded it in and welded up some new brackets to fit the factor RR seat latches.
I found the fairings on ebay, just kept watching till I got a good deal.
