600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
f4 to f4i
Old Apr 12, 2011 | 01:35 PM
cuetip's Avatar
Default f4 to f4i
ok guys i have been looking everywhere and i would like to no how do u wire up an f4i cluster instead of an f4 cluster?? i no u have to get the upper stay the f4i cluster and the f4i front fairing, but anyone no how to wire up the cluster
Old Apr 15, 2011 | 05:03 PM
cuetip's Avatar
come on guys i would like to no
Old Apr 15, 2011 | 07:37 PM
Conrice's Avatar
hey man, search the forums with the search bar... i'm sure its in the mechanical how-to
Old Apr 15, 2011 | 09:54 PM
cuetip's Avatar
I have quite a few times and found one about f4 to f4i but nothing about an f4 to f4i
Old Apr 18, 2011 | 04:20 AM
cuetip's Avatar
I mean I found ones about f4 to f4i but not f4 to f4i
cuetip's Avatar
I mean I found ones about f3 to f4i but not f4 to f4i
Old Apr 19, 2011 | 11:18 AM
adrenalnjunky's Avatar
well the F3 to F4i swap will give you the basics - same concepts. The rest you'll probably need to break out some wiring schematics of the 2 bikes, compare what is the same and then start looking for workarounds for the rest.
none of this stuff is straightforward - if no one else has done it before, and there truly isn't a how-to on here, then it's time to start your own.
Old Apr 23, 2011 | 02:51 AM
donte191's Avatar
Match up wire for wire .....I jus did the swap it was a 20 minute job
Old Apr 23, 2011 | 11:11 AM
gotcbr's Avatar
F4 to F4i gauge swap is *not* an exact wire-to-wire swap.
If you've done an F4-to-F4i gauge swap, I'd certainly like to see it w/ detailed pics & instructions. Perhaps do a how-to post.
While there have been "write-ups" in the past, there's not been anything in detail w/ pics & organized instructions like a proper how-to.
Old Apr 23, 2011 | 05:45 PM
Bladed101's Avatar
+1 The gauge swap is not a straight across swap there are a few wires that need to be swapped. You will also need a Temp sensor from 1999 cbr900RR. If you dont swap the sensor then the gauge wont read the right temp.
Here are the threads I used for my swap it is very easy to do.
https://cbrforum.com/forum/cbr-600f4...ap-help-98780/
https://cbrforum.com/forum/cbr-600f4...wap-pic-93064/
