600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
F3 SSSA wheel alignment question
Old May 4, 2011 | 02:55 PM
nvanvlymen's Avatar
Default F3 SSSA wheel alignment question
I've been putting my f3 sssa project into effect.
got most things done, top shock mount, new sprocket and chain, new wheel.
There lies the problem. I mounted the rim up, and noticed im running a positive offset of at least 20mm.
The swing arm is mounted as far left into the F3 frame as possible, with exception to the spacer that came with the swingarm (mounts on the chain side of the swingarm) there is a little room there to shave off, but i don't think it would make too much difference.
As you can see, there is not much room to shave off.
I'm at a loss as to what i can do to get the tire centred. There is no spacer between the hub and the rim, it sits flush.
Any help from guys who've done this would be great!
Thanks,
n
Old May 5, 2011 | 07:39 AM
nitrodude's Avatar
Theres always the frame you cna grind...
Old May 14, 2011 | 12:36 PM
scorpionvmu's Avatar
2011 Ride of the Year
it looks like the project has been moving along.
you know there is always few problems we run into trying to mod, but whatever the resolution, the final product is worth every headache you get on the way.
keep your head up, there is a solution to that problem somewhere, youll find it.
Old May 19, 2011 | 09:28 AM
VALKYIE's Avatar
What year and model swingarm are you using?
Old May 19, 2011 | 10:50 AM
G9 DUB's Avatar
Why don't people use the later swingarm there's only 15mm difference between them you could just cut of the spacers on the inside of the frame to get this back, or is there some other difference like the radius of the arm???
CBRclassic
How To's
Feb 27, 2013 07:10 AM
98F3_colorado
May 16, 2011 09:43 PM
deadfred
F2 Tech
Jul 15, 2010 01:39 PM
krayton
Apr 8, 2008 08:49 PM
kiddkatana
Apr 7, 2008 10:29 PM
