600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
F3 - GSXR Caliper swap?
Old Sep 14, 2009 | 10:32 AM
johnnyx's Avatar
Default F3 - GSXR Caliper swap?
Looking to swap out the F3 calipers for something bigger and more intimidating. Not really a performance issue. I can get a set of 07 GSXR calipers on the cheap, and I was wondering if mounting them would be an ordeal. Also, would I need to swap the master cylinder? Failing all that, are there any aftermarket ones out there?
Old Sep 14, 2009 | 04:50 PM
cajunlowrida's Avatar
Those calipers are radial mount, so yes, the easiest thing would be to do a gixxer fork swap. I would recommend swapping to the radial master as well, although Im sure you could retain the stock one if willing to sacrifice some brake fade.
Old Sep 15, 2009 | 09:34 AM
johnnyx's Avatar
Yeah; too much work, too expensive, screw it. Thanks.
Nuka
Aug 31, 2012 12:44 PM
segraves1
Sep 22, 2011 03:31 PM
newnut
Jul 22, 2011 07:46 PM
jjennings153
Apr 7, 2009 11:27 PM
noobF3er
Aug 15, 2008 11:55 PM
