F3 - GSXR Caliper swap?
Looking to swap out the F3 calipers for something bigger and more intimidating. Not really a performance issue. I can get a set of 07 GSXR calipers on the cheap, and I was wondering if mounting them would be an ordeal. Also, would I need to swap the master cylinder? Failing all that, are there any aftermarket ones out there?
Those calipers are radial mount, so yes, the easiest thing would be to do a gixxer fork swap. I would recommend swapping to the radial master as well, although Im sure you could retain the stock one if willing to sacrifice some brake fade.
Yeah; too much work, too expensive, screw it. Thanks.
