600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
99 F4 Fuel Pump issue
Old May 8, 2007 | 03:14 PM
bushwiq1's Avatar
Default 99 F4 Fuel Pump issue
Real quick. How can you tell if your fuel pump is actually working. I disconnected it from the connection by the battery and started the bike, I used a light tester and put it into the connector but the light did not come on. How do you actually test the fuel pump.
Old May 8, 2007 | 03:23 PM
bindelsf2's Avatar
Default RE: 99 F4 Fuel Pump issue
try and disconnect the end from the engine and see if it will pump gas from the tank into a container??
Old May 8, 2007 | 03:49 PM
bushwiq1's Avatar
What i did do was disconnected it from the the connector under the seat. I rode the bike for a minute until it would not go any more. I don't know if that was a clue or not. When you say disconnect, do you mean the hose or the power wires leading to the fuse box and battery?
Old May 8, 2007 | 04:06 PM
bindelsf2's Avatar
i would disconnect the hose from the outlet side, where it goes into the engine. and just aim it in a bucket start it up and see if it pumps fuel from the tank through the pump and into the bucket..
jondecker83
Nov 19, 2014 05:14 PM
kfunk
Aug 3, 2010 10:02 AM
22opel
Apr 28, 2010 06:07 PM
houstono1
Mar 23, 2010 09:39 AM
600rr12
Nov 14, 2008 12:32 PM
