where to mount led's?
Old May 11, 2007 | 06:56 PM
schultzy's Avatar
Default where to mount led's?
im adding 4 to 6 electropods to my 06 f4i. where do you guys usually mount them to look the best.i already put one facing down over the back tire and one right under the spring facing the rear.the area around my rear tire and spring looks pretty good but what about the front. i also would like to light up the opening in each side cowl but i dont know where to mount them without getting them too hot?
Old May 11, 2007 | 07:00 PM
D2VW14_20's Avatar
Default RE: where to mount led's?
Inside te front fairing and towars the back on the frame.
Old May 11, 2007 | 07:56 PM
SchiraF4I's Avatar
I zip tied mine to my air duct in the side opening. and right above the rear shock there is a bar zip tied there too. and in the back i drilled it into the plastic behind the plate.
Old May 13, 2007 | 01:25 AM
florida boy's Avatar
lets see some pics
Old May 21, 2007 | 06:15 AM
FFCBRf4i's Avatar
+1
where the pics at?
Old May 21, 2007 | 08:44 PM
RojerLockless's Avatar
I'll post mine soon
1 on each of the frame openings where the hole in the fairing. 1 of those bar's under the spring on the swing arm. 2 on each side of the subframe near the pasanger pegs, and 1 bar under the very front under the headlight over the front fender
Old May 24, 2007 | 02:12 AM
Sabor600rr's Avatar
Ok guys here goes, hopefully it works....
and heres a lil vid of the neons in action----->http://s78.photobucket.com/albums/j8...t=MVI_0662.flv
Old May 24, 2007 | 02:17 AM
Sabor600rr's Avatar
Old May 24, 2007 | 03:39 AM
chpsk8er630's Avatar
Im working on some leds right now. I ordered 40 5mm leds and resistors for them. It was less than 20$ from www.oznium.com. The other stuff that i had already was a switch, fuse and wire, and all the soldering supplies. Im installing them now but it takes alot of time doing it from scratch like i am. I will get some pictures when it is all done by the end of next week. sry to keep you waiting. lol
Old May 24, 2007 | 11:38 AM
Sabor600rr's Avatar
Heres a suggestion when putting in the lights...try to use quick disconnects.Helps out when your working on your bike. This way you can take each fairing off without having wires of Leds all over the place. I did it to mine and I can do a quick oil change and not have wires hanging.I got 7 leds but they are stupid bright and arethe size of a quarter.
dietDrThunder
Aug 28, 2009 11:46 AM
traitorhound
Mar 11, 2008 06:53 AM
05f4i16
Mar 16, 2006 12:25 AM
RCKT GRL
Jan 16, 2006 10:15 PM
