Swing arm Painting
Old Jan 25, 2010 | 01:32 PM
philthethrillohio's Avatar
Default Swing arm Painting
ok so i got quoted 65 to get my swing arm powder coated so i am going to try and take it off myself . is there anything i should know? i heard i need to replace the bearings. can i just remove the original and put back in ? i have heard its a pain to get them out. someone shed a little light for me. thanks
Old Jan 25, 2010 | 02:05 PM
Kuroshio's Avatar
It's not required but its a good chance to inspect the bearings and replace if necessary. Definitely take the opportunity to lube everything.
Hardest part of removing the swingarm is gonna be securely supporting the bike while removing it and getting the pivot bolt out if it's never been done. Disconnecting / reconnecting the rear shock is only worth minor cussing.
Old Jan 26, 2010 | 09:10 PM
viper03's Avatar
I am tackling that same project. I've been told, (with on the plastics off) putting the bike on a center stand lifting on the header and strapping the foot pegs to the stand with ratchet straps - works? I'm worried about lifting the bike on the header.
Old Jan 28, 2010 | 02:51 PM
i have seen it done with to jack stands attached to a bolt were the swing arm was with a support from the rear. i saw it on another cbr forum. what i m most worried about is i have to take out the bearings and doing so they will get damaged then i have to put new ones in . dont no the proceedure.
Noah0708
Nov 15, 2008 10:31 AM
dominicanwonder5
Apr 21, 2008 02:40 AM
SwashBuckler
Apr 11, 2007 11:47 AM
Drake
May 24, 2006 02:52 PM
F4iGuy33
Mar 28, 2006 12:30 PM
