Scorpio Alarm Ignition Cut Off
Old Apr 25, 2006 | 11:55 AM
KIT1K's Avatar
Default Scorpio Alarm Ignition Cut Off
I just installed the Scorpio Alarm System with Perimiter Sensor. It is a nice feeling to know that my bike is as protected as can be outside. Even though I lock it up to my car at night...I still worried about it each night. Last night was the first good night of sleep since I bought my bike.
My question is I also got the ignition cut off module for the Scorpio, but it requires me to tap into the Ingnition Module. Does any one know where that is located. I checked the 2005 600RR service manual and I see where the ignition switch wire is, but not sure if it is the same as the ignition switch module? Any help would be appreciated.
[IMG]local://upfiles/6151/C13C6DB94B9442D7BE1B5BFDCFE19273.jpg[/IMG]
Old Apr 25, 2006 | 12:03 PM
KIT1K's Avatar
Default RE: SportVue Heads up Display
Just got the Sportvue heads up display unit. I had no problems setting the helmet up with the HUD, but am haveing difficulty with the installation of the multiple sensory unit (MSU). I have to get to the RPM ourput wire. I think that I have located it, but it is under the tank. Any instructions on how to remove the tank so I can tap into the RPM output wire? Any help would be most appreciated?
I have had this for a few days and am trying to get this installed...nothin like having a new toy for your bike and not being able to use it... Got my radar set up, but would like to be able to hook it into the Heads up display...
[IMG]local://upfiles/6151/18A70B3B4ED44013828944AF7297C4CF.jpg[/IMG]
Old Apr 25, 2006 | 02:46 PM
slolane's Avatar
Not exactly sure myself but am interested also as I have an 05 F4i with the same setup. I currently have everything installed except the cut off. I have also been thinking that since the manual mentions 5 different ways to wire in the cut off now may be a good time to wire up some additional switches. Brings back memories of my Jeep TJ that had 2 in it. If I figure out something in the meantime I will be sure to let you know.
600cbr18
Feb 1, 2011 11:20 AM
bieniu
Mar 27, 2008 10:01 PM
