Steering Damper?
Old Apr 21, 2006 | 07:00 PM
i3041's Avatar
Default Steering Damper?
One of the many mods I'm planning on doing on my 06 600RR is a steering damper. Lots of people have told me that it's worth having. But what exactly does it do, and what sort of a difference will I notice? It's a pretty expensive device from what I found out today and I just want to be sure it's worth doing. Any feedback would be appriciated.....thanks!
Old Apr 21, 2006 | 07:42 PM
Tahoe SC's Avatar
Default RE: Steering Damper?
when your front tire comes off the ground and you don't set it down straight, you get wobbles. the damper prevents the wobbles and/or lessens them.
do you need it on the 600rr? well...people who ride hardcore track and twists have them for insurance...just in case because they are pushing the bikes hard.
do you need one? well, if you're not track superstar you don't.
the most important thing is to set up the suspension properly, and then you wouldn't need a damper...until you get to that hardcore level. don't use the damper as a band aid to a jacked up suspension setting.
lots of posers have them though because they think it's cool.
Old Apr 21, 2006 | 07:50 PM
i3041's Avatar
Thanks for the reply. That's interesting. See I'm not a hardcore rider by any means and I don't ride on the track. I'm a new rider, and at this point I'm not planning on doing anything that would lift the front tire. It sounds like this might be a mod I can skip......or maybe not. The jury is still out in my mind as to if it's worth having done. Maybe others will post and I can get some other feedback. Thanks again!
Old Apr 22, 2006 | 05:53 AM
dragonium25's Avatar
Hi, I'm a new rider as well and a friend of mine told me a damper was one of the first mods I should get. But I'm not a hardcore rider either (or should I say yet) so I'm too sure if I really need one now. But Tahoe SC did mention something about "as long as you get your suspension set right" and I'm interested in how you do that, or how do you know if it's set right? What am I looking for when I'm trying to get it set right?
Old Apr 22, 2006 | 06:57 AM
i3041's Avatar
ORIGINAL: dragonium25
I'd rather not turn this into a suspension thread because there is a lot of those already. I actually searched "suspension settings" and got a lot of information. I'm going to set mine up soon. Also your owner's manual will have info that is usefull on suspension.
So back to the original question about sterring dampers..........does anyone else have any input for us?
Old Apr 24, 2006 | 03:06 AM
jorge13's Avatar
Tahoe and all you guys !
In the new 2006 model you do NOT have any form to fit a different setting from factory.
It does not has any possibility to do it![>:]
Old Apr 24, 2006 | 08:30 PM
i3041's Avatar
ORIGINAL: jorge13
What do you mean by this? Can you please explain...thanks!
Old Apr 25, 2006 | 02:25 AM
jorge13's Avatar
i3041, hi there !
Difference from older models the 2006 do not have any possibility to change the factory settings, it just does not has any screw or nut to do the thing ! ( In the front )
Old Apr 25, 2006 | 05:23 AM
i3041's Avatar
Interesting, and thanks for clarifying that for me. I guess on the new bike it's not neccesary to add a damper. I love how this thing handles anyway. I'll spend my money on other things!
Old Apr 25, 2006 | 07:58 PM
Tahoe SC's Avatar
What? the new forks should be the same as the old ones.
