LED TURN SIGNALS PROBLEM
Old Jul 31, 2007 | 11:53 PM
walt1972's Avatar
Default LED TURN SIGNALS PROBLEM
Hi,I installed a set of rear LED turn signal but they do not blink,they come on but won't blink at all.I know there is a resistor out there to solve this problem but i would like to know if I can use an in line resistor,possible? Thanks.
Old Aug 1, 2007 | 05:31 AM
Blue Fox's Avatar
Retired Moderator
Default RE: LED TURN SIGNALS PROBLEM
So, you have LED's in the front AND in the back right?
If you do, then yes, you need resistors. You can go to Autozone, Checker, etc. and get their LED resistors. They're a little large, but that's no problem. You can also order smaller resistors (but they get much hotter) online too.
Old Aug 1, 2007 | 09:48 AM
woodyracing's Avatar
do the front and rear signals operate on seperate relays or are they both running off the one by the headlights?
don't have access to a wiring diagram at the moment
Old Aug 1, 2007 | 10:11 PM
walt1972's Avatar
Thanks guys i installed an in line resistor for each rear light and that did it,cause the front and rear lights work off the same relay,thanks again.
Old Aug 1, 2007 | 10:13 PM
walt1972's Avatar
hey,thanks i got the problem solved by installing resistors,thanks.
Lowridese
May 1, 2010 01:12 AM
MrBlaze
Aug 17, 2009 02:07 AM
dewthedoo05
Sep 4, 2007 09:32 PM
zachharter
Jul 6, 2007 06:56 AM
