intergrated turn signal/brake light question
Old May 4, 2008 | 11:00 AM
Gip714's Avatar
Default intergrated turn signal/brake light question
ok so i have my tail section off and i know where to plug in my brake light but for the turn signals, i have no clue. the directions that came with them suck *** and dont tell me **** and im not that great with this kinda stuff anyways, so i need help. there are 3 plugs plus the actual brake plug, white, blue, and another color i cant remember. are those my turn signal wires? and if so, does anyone know which is which?
Old May 4, 2008 | 09:15 PM
odysseyzray's Avatar
Default RE: intergrated turn signal/brake light question
Black or black with white stripe, some olderCBR has iton brownshould be for the tail light.
Left turn should be orange.
Right turn should be blue.
Blacks or greens, is ground.
Good luck ... hope this helps
Old May 4, 2008 | 11:13 PM
gotobatter's Avatar
+1 odyssey
Old May 5, 2008 | 01:04 AM
Gip714's Avatar
thanks man, after i posted this, i just went down and started testing things out. i figured out which is which, i just took the wire and stuck it in the plug hole and they started blinking. now to cut the plugs off and see which wire i use is the only question now. bc i believe once i cut the plug off there will be 3 wires not just one, i could be wrong tho, i couldnt tell bc the rubber harness was in the way.
Old May 6, 2008 | 03:28 AM
Nimbus87's Avatar
Its a pain if you are going to use the resistors (you have to cut into the wire harness). What you want to do is cut the ends off of your stock blinkers, wire them up to your intergrated one,then you justconnect the colors together and wala.Test them before putting your tail back on (so when you hit left it blinks left).
Old May 6, 2008 | 11:40 AM
Gip714's Avatar
thats the thing, the guy that owned it before me took the factory blinkers off and when he took the tail section off he just disconnected them at the plugs. So instead of being able to do that I have to cut off the other plug then connect the blinker wire, but that'll leave 2 exposed wires.
hockeyryan
Nov 30, 2011 02:23 PM
NickV
Jan 22, 2010 08:46 PM
Hotswap
May 12, 2008 11:47 PM
sharker98
Dec 4, 2007 09:58 PM
felk27t
Jun 29, 2007 10:53 PM
