Help...oil leak
Old Mar 23, 2006 | 11:07 PM
isolated1523's Avatar
Retired Super Moderator
Default Help...oil leak
Had my right side engine/clutch cover powdercoated, and now i have a problem. I have a feeling that it's something small but not sure where to start. When i get above 8 or 9000rpms, oil begins seeping out of the top of the clutch cover via the linkage rod. I ran some silicon around the washer, which slowed it but didn't fix the problem. Did i not regrease the bearings enough, or is there some kind of small seal that goes around the rod that i forgot? Anyone got a picture of the install breakdown?
-Adam
Old Mar 28, 2006 | 12:56 AM
ghostryderz's Avatar
Default RE: Help...oil leak
hey man, you might want to check to see if there is any built up powder coat around the spot . That stuff tends to build up and not let the cover sit right.
ko67
F2 Tech
Sep 20, 2011 10:47 AM
vegas_rebel
Aug 28, 2011 12:10 PM
graysonwittwer
Aug 17, 2011 05:40 PM
amir145
Sep 1, 2010 11:33 AM
airick
Apr 17, 2007 06:58 PM
