Help isntalling flush mounts
Old Sep 30, 2008 | 07:00 PM
jarhead89x's Avatar
Default Help isntalling flush mounts
Hi, my friend just bought flush mounts and he wants me to install it for him since I did mine. The thing is, his flush mounts are different from mine. They come with the blinkers, the plastic washers, and these blue plastic pieces. I think they are used to clip onto the blinker wire assembly (made that up). Not sure how I am supposed to connect the flush mount wires to the plastic pieces. They say AWG 18-14 on them. Does anyone know what to do with these?
Old Sep 30, 2008 | 07:53 PM
FLYOU's Avatar
Default RE: Help isntalling flush mounts
this thing?
Old Sep 30, 2008 | 07:57 PM
D2VW14_20's Avatar
If so, wire through holes, twist together, bend bare wire back in close sh,t.
Old Sep 30, 2008 | 09:04 PM
jarhead89x's Avatar
Wow, that was so simple. Took me about 20 minutes just looking at it and trying to figure it out. In the end, all I did was cut the stock blinkers off and just rewired the flush mounts onto it (eh, is that understandable?) Anyway, sorry about the question. I kind of ghetto rigged it without using those blue plastic connector things. But thanks for your input. Yeah, the flushmounts were successful. Took only about 45 minutes to do my friend's bike.
Old Sep 30, 2008 | 10:14 PM
D2VW14_20's Avatar
Honestly, I use butt connectors over those.
Old Sep 30, 2008 | 10:32 PM
jarhead89x's Avatar
BTW, how will it work if you are supposed to put the negative and positive wires through those two holes? Isnt the metal piece one piece itself?
Old Sep 30, 2008 | 11:03 PM
Blue Fox's Avatar
Retired Moderator
You use one for the positive, one for the negative.
Best thing to do is cut off the connector off the old stock turnsignal.....then crimp it on the new signals, using butt-connectors or pig-tail connectors (or solder it).
Old Sep 30, 2008 | 11:11 PM
D2VW14_20's Avatar
Its only one side.
Old Oct 1, 2008 | 12:49 PM
jarhead89x's Avatar
ORIGINAL: Blue Fox
Oh okay. One plastic piece for each, neg and pos. Yeah, I just ended up cutting the old connector off the stock signals. But then, all I did was twist the wires together and E-taped it.
nickp123
Mar 21, 2011 01:03 PM
Decah
Dec 13, 2008 05:29 PM
quek
Nov 13, 2006 06:37 PM
psycojester
Apr 23, 2006 08:24 AM
Da CbR KiD
Mar 20, 2006 08:01 PM
