Flush Mounts
Old Nov 11, 2006 | 09:39 PM
quek's Avatar
Default Flush Mounts
I got a problem, i installed some flush mounts, but now they blink really really fast and on the opposite side. How do i fix this problem?
Old Nov 12, 2006 | 01:42 PM
N8 Dawg's Avatar
Default RE: Flush Mounts
If they blink on the wrog side, you must have swaped the wires somehow? Mine were blinking fast and I didnt have a good connection.
Old Nov 12, 2006 | 08:54 PM
cwmc29's Avatar
If the flush mounts are LED, then you need to replace the resister. The LED's use less power and this causes them to flash faster. I have just done the same for the front of the bike and when I get the rear intergrated taillight, I will be replacing the resister. I will talk to my tech buddie and find out what you need.
Old Nov 13, 2006 | 12:11 PM
quek's Avatar
just to make sure...
can someone tell me what each color represents?
Old Nov 13, 2006 | 06:37 PM
cwmc29's Avatar
With flush mount LED's the white wire will be ground. It must be hooked up. The other two you'll have to test to see which one is the constant feed, for the running lights and the other is the intermitant feed or the turn signal. Do not hook ut the constant feed. My LED flush mounts do not have the running light option so I did not hook this up.
nickp123
Mar 21, 2011 01:03 PM
hopper662
Jul 28, 2008 11:39 PM
Lego
Jun 28, 2008 07:51 PM
lance_buma
Jun 22, 2007 12:23 AM
Da CbR KiD
Mar 20, 2006 08:01 PM
