CBR 600RR highbeam mod idea
Hey everyone! I was thinking of running some LEDs around my cbr600rr to increase visibility at night, basically tucked within the fairings to illuminate the engine and glow out of the slots between fairings. I wanted an opinion as well, should I wire them to my high beam light so I turn them on when I use my highbeam at night, or should I use a separate battery unit and a switch dedicated to these LEDs alone? Let me know what you think, thanks!
Hi , think its better to run them through a separate switch and relay , have you had a look at amperage on your bike and how much more the led's are going to use , as to not overload the system:0
Underglow kits have been around for a long time. If you like the look of them, go for it. Make sure to check local laws for the legality of using them while moving and color choices. Usually, at minimum, red can't face forward, white can't face backwards, and sometimes blue is reserved for law enforcement.
