Highbeam useless?
Old Nov 25, 2007 | 02:21 PM
woo545's Avatar
Default Highbeam useless?
Does anyone else feel that the highbeam on the F2 is basically useless? As soon as I turn mine on, I then can no longer see the roadway as clear as before....sure the signs further ahead are clearly lit, but the area that was covered before essentially becomes a blind spot.
Old Nov 25, 2007 | 02:55 PM
redcbrman's Avatar
Default RE: Highbeam useless?
I find my lowbeam much worse, even with the highbeam on I can barely see anything. I just about wrecked three times on my last trip because I couldnt tell the road was curving in front of me until I was right on it. Going 75 mph (and that was just above the speed limit, I wasn't racing) I ended up slowing down to 10 mph below just so I could have more time to react to turns in the roadway.
Old Nov 25, 2007 | 05:33 PM
FNQuickF2's Avatar
ORIGINAL: woo545
Dude! That's why it's called "HIGH" beam...You're able to see up farther ahead, while losing the immediate light path in front of you...Now if the F2 had a dual headlight system, that would be bad ***...
RB
Old Nov 26, 2007 | 08:57 AM
eweppley's Avatar
Yeah, it sucks. But other than trying to convert it to a dual light system, what can you do other than slow down a little?
Old Nov 26, 2007 | 08:21 PM
410600f2's Avatar
If your not useing silverstars give them a try. they help a little
Old Nov 27, 2007 | 03:04 PM
MikeInCtown's Avatar
ORIGINAL: 410600f2
I have that one in my bike and the high beam is just as the OP described. Low works much better and you only lose a little light in the distance. Not sure why since lots of auto single headlights work really nice on high even up close as well as far.
Old Nov 27, 2007 | 04:35 PM
bmg velocity's Avatar
ORIGINAL: woo545
It's useless in certain situations.
If you are level to an approaching object you want to avoid, say a dimly lit curb, it gets worse/more useless the closer you get.
However for long distance sight, and if you are coming down a hill like onto a highway on-ramp, it's occasionally a life-saver.
Old Nov 27, 2007 | 10:05 PM
undercoverbrother's Avatar
folks...feel free to use the **** behind the headlampto adjust the light beam. mine was extremely off. but after some adjustments.....like magic. i could see in the dark again. yayy. oh and im using hyper whites.
Old Nov 28, 2007 | 06:12 AM
woo545's Avatar
There's a ****?????[:-]
Old Nov 29, 2007 | 02:58 PM
i believe there is anotherone across from this one. been a while since i took it off.you should be able to see it with the front side fairings off
RyanEricW
Sep 8, 2010 11:34 AM
Sand.Man
Dec 23, 2007 08:38 PM
HAVOC
Aug 30, 2007 04:15 PM
Chuck Norris
Oct 11, 2006 03:13 AM
Triangle
Oct 9, 2006 05:25 PM
