Highbeam useless?
Does anyone else feel that the highbeam on the F2 is basically useless? As soon as I turn mine on, I then can no longer see the roadway as clear as before....sure the signs further ahead are clearly lit, but the area that was covered before essentially becomes a blind spot.
RE: Highbeam useless?
I find my lowbeam much worse, even with the highbeam on I can barely see anything. I just about wrecked three times on my last trip because I couldnt tell the road was curving in front of me until I was right on it. Going 75 mph (and that was just above the speed limit, I wasn't racing) I ended up slowing down to 10 mph below just so I could have more time to react to turns in the roadway.
ORIGINAL: woo545 Does anyone else feel that the highbeam on the F2 is basically useless? As soon as I turn mine on, I then can no longer see the roadway as clear as before....sure the signs further ahead are clearly lit, but the area that was covered before essentially becomes a blind spot. RB |
Yeah, it sucks. But other than trying to convert it to a dual light system, what can you do other than slow down a little?
If your not useing silverstars give them a try. they help a little
ORIGINAL: 410600f2 If your not useing silverstars give them a try. they help a little |
ORIGINAL: woo545 Does anyone else feel that the highbeam on the F2 is basically useless? As soon as I turn mine on, I then can no longer see the roadway as clear as before....sure the signs further ahead are clearly lit, but the area that was covered before essentially becomes a blind spot. If you are level to an approaching object you want to avoid, say a dimly lit curb, it gets worse/more useless the closer you get. However for long distance sight, and if you are coming down a hill like onto a highway on-ramp, it's occasionally a life-saver. |
folks...feel free to use the knob behind the headlampto adjust the light beam. mine was extremely off. but after some adjustments.....like magic. i could see in the dark again. yayy. oh and im using hyper whites.
There's a knob?????[:-]
http://i4.tinypic.com/7yountv.jpg
i believe there is anotherone across from this one. been a while since i took it off.you should be able to see it with the front side fairings off |
