Headlights only work on highbeam
Old Feb 21, 2007 | 03:05 AM
XXCBRChrisXX's Avatar
Default Headlights only work on highbeam
hi CBR fanatics my headlights only work on the highbeam setting and shut off completely when turned to the lowbeam
any ideas anyone?
Old Feb 21, 2007 | 06:53 AM
Ghost1Rider's Avatar
Default RE: Headlights only work on highbeam
First check the bulb, then your light switch.
Old Feb 21, 2007 | 07:02 AM
madkawa's Avatar
When you turn on the high beam, only 1 side comes on or both sides?
If one side then all your low beam bulb probably blown, just change the bulb.
if both comes on then check your wiring..
cheers
Old Feb 21, 2007 | 01:00 PM
both sides come on on high beam noting comes on lowbeam
Old Feb 21, 2007 | 05:58 PM
Motor_Fan's Avatar
your left bulb is the only one that works on low beam. Thats how the original wire harness is made. Therefore for sure your left lightbulb aint working on lowbeam.
Tricky to change thow, I find that the best way is to remove the screen, and the plastics around the speedo / tach, and access it from the top.
Regards
Old Feb 21, 2007 | 08:22 PM
i see how do you get the bulbs out of the plastic? give it a counterclockwise twist? i fiddled with this last night but didnt try to hard as i didnt want to break anything. and not haveing my honda oem manual yet im just leting it be and driveing it
Old Feb 21, 2007 | 11:01 PM
MarkR's Avatar
My low beam is two bulbs
kazo
Mar 1, 2011 05:40 PM
alysiak00
Sep 25, 2010 02:26 PM
bllund2
Sep 28, 2008 02:22 PM
mkfoxxx
Mar 16, 2007 06:14 PM
01929RR
Sep 26, 2006 03:16 PM
