Headlights only work on highbeam
When you turn on the high beam, only 1 side comes on or both sides?
If one side then all your low beam bulb probably blown, just change the bulb.
if both comes on then check your wiring..
cheers
cheers
your left bulb is the only one that works on low beam. Thats how the original wire harness is made. Therefore for sure your left lightbulb aint working on lowbeam.
Tricky to change thow, I find that the best way is to remove the screen, and the plastics around the speedo / tach, and access it from the top.
Regards
Regards
i see how do you get the bulbs out of the plastic? give it a counterclockwise twist? i fiddled with this last night but didnt try to hard as i didnt want to break anything. and not haveing my honda oem manual yet im just leting it be and driveing it
