600RR Blinker Electrical Problems and Questions?
Old Dec 28, 2006 | 10:06 PM
429dhm's Avatar
Default 600RR Blinker Electrical Problems and Questions?
I have a question regarding the signal light flasher relay. I know it is intergrated into the instrument cluster but should I hear it clicking (when in a left/right postion) with no signal lights installed?
I had LED lights in the front and nothing connected in the rear and the signal light relay was not clicking and there was no indication on the instrument cluster.
Old Jan 2, 2007 | 02:00 AM
dcope17's Avatar
Default RE: 600RR Blinker Electrical Problems and Questions?
The Relay is really quiet, I don't know if you can hear it click. If you have an LED turn signal plugged in and no load resistor, It will flash so fast, that it almost seems to stay on. If you're having other trouble, make sure that the plug in the back of your guages is all the way in. I pluged mine in once and everything worked except the turn signals. After thinking I screwed it up, Ifixed the plug and everything was fine.
Stims9250
May 19, 2012 10:45 AM
estate4life
Mar 16, 2012 12:09 PM
Shortysboy09
Jun 10, 2008 08:34 AM
vasol
Mar 26, 2008 11:10 PM
Steve600RR
May 23, 2007 07:32 PM
