-1 front sprocket = chain whine?
Old Jun 26, 2008 | 07:23 PM
jstew600's Avatar
Default -1 front sprocket = chain whine?
I installed -1 tooth front sprocket and now when holding at steady throttle (cruissing along) I get a whine. I figure it is the chain , but why? I noticed the factory sprocket has a rubber piece on both sides of the sprocket and the new one is just steel.I have tried loosening and tightening the chain with no effect.
Old Jun 27, 2008 | 09:15 AM
ffingers's Avatar
Registered Users
Default RE: -1 front sprocket = chain whine?
the rubber grommet doesn't cause any sound when removed (although that is what it is there for)..i went -1 in the front and i don't have a whine at all....when you changed out the sprocket...you change out the chain?
what pitch did you stay with?
a little more info on the swap might help...
Old Jun 28, 2008 | 09:32 AM
jstew600's Avatar
Just the sprocket, and stayed with the stock chain 525.
Old Jun 28, 2008 | 09:39 AM
PlayfulGod's Avatar
ORIGINAL: jstew600
thats why. Its best to replace chain/sprockets as a set.
comodidit
Aug 12, 2012 02:49 AM
deadfred
F2 Tech
Apr 17, 2010 06:52 AM
christhek
Aug 1, 2006 10:12 PM
