Power Commander Installed 07' CBR1000
Old Jul 22, 2008 | 07:55 AM
buffddy16's Avatar
Default Power Commander Installed 07' CBR1000
Hey guys. Got my Power Commonder installed last night on my 1000. Not a difficult job at all. Took about 2 hours and we were done. I loaded the map on it that matches my exhaust for the time being until i get it on a dyno to have it tuned. But im stoked about it how its set up now because it made all the difference in the world. Pulls so much harder all around. For the most its set up richer until i get up above 9000rpm and then it goes leaner than stock. at 4000rpm its dumping 27% more fuel than stock. Awsome add to the bike i def recommend it to anyone. Well worth the money to get one.
Old Jul 22, 2008 | 02:59 PM
MgA_ODEN's Avatar
Default RE: Power Commander Installed 07' CBR1000
Did you do the accelerator pump mod?
Old Jul 22, 2008 | 03:09 PM
MgA_ODEN's Avatar
For those who don't know .............
The accelerator pump utilitykeeps the A/F ratio from spiking lean when the throttle is abruptly opened. When the throttle is opened rapidly there is some interpolation of the map values by the ECUand it cannot match the fuel to the volume of air rushing past the butterflies. This pretty much fixes that problem.
Think I have mine set at 90,15,20
Old Jul 22, 2008 | 03:21 PM
buffddy16's Avatar
No i didnt and i did notice that when you smash the throttle from an idle it seems like a delay is that what you are talking about? where do i get the accelerator pump mod from?
Old Jul 22, 2008 | 04:49 PM
MgA_ODEN's Avatar
Software[/align]
PCIII USB Accelerator Pump[/align]
http://www.powercommander.com/downlo...PumpEnable.zip
PDF File
PCIII USB Pump Utility Installation Guide[/align]
http://www.powercommander.com/powerc...eratorPump.pdf
Old Jul 24, 2008 | 05:35 AM
Balamien's Avatar
Thanks for the info on this MgA, I got mine in the other day and did this along with the calibration and stock map and BMC filters. The only problem I had was the tank cover. Is there any easy way to get that thing back on over the rubber O ring around the filler part? It took me about 6 tries and its still on even around the circle but close too it. Other then that, the tank cover bolts on the bottom are a real pita to get off.
Old Jul 29, 2008 | 09:25 PM
mercenaryferret's Avatar
is this a problem w/ the Two Bros Juicebox as well?
Old May 24, 2011 | 11:56 AM
papadaca's Avatar
I will be picking up a GPR full system around the first. I will install my power commander soon. I will be taking my bike to the Dyno at my old school to get a custom map made for it.
Old May 24, 2011 | 01:23 PM
yumoncbr's Avatar
August 2011 ROTM
Put oil or grease on it before you slap it back on.
vinny coyle
May 16, 2009 07:26 AM
joe-4422
Apr 7, 2009 09:47 AM
buffddy16
Jul 11, 2008 01:12 PM
maxwell139
May 16, 2006 01:30 AM
sikanimator
Dec 6, 2005 01:42 AM
