PCIII Question
Old Apr 21, 2006 | 10:36 AM
Socrates's Avatar
Default PCIII Question
Hi Guys,
Since I put on a Sato Racing slip-on on my '06 1K about a week ago, I have noticed that off idle in 1st there is more noticeable flat spot or delay before the bike starts to accelerate. I find it takes about a seocnd after opening the throttle off idle and then bang the power kicks in ...I mean I realize that the bike is flat in general under 3-4k rpm...but this seems to have gotten a bit worst with the slip-on.
Will a PCIII mapped to my setup do anything to improve this under 4k rpm ? Also....is there a PCIII available yet for the '06...it seems like there is not ...but many say the 'o5 model works on the '06 ?
Advice appreciated
Phil
Old Apr 21, 2006 | 03:50 PM
Socrates's Avatar
Default RE: PCIII Question
Hi Again..
An update to my first question/post:
I called my local Honda shop that also provides performance tuning/dyno services...and this is what I was told:
-that even after installing an aftermarket slip-on the bike should automatically adjust without the need for a PCIII. They said that it can adjust by about 8% +/- for a slip-on and in most cases is not even needed. A full exhaust is another story however.
- MORE important is to install a freer flowing air filter to compensate for the fact that air is leaving the "back of the back" alot faster
So the recommendation was to FIRST try an air filter (eg. K&N) and see if that improves throttel response before going the PCIII route
Does this make snese ? Anyone found that a slip-on with just an air filter like a K&N (no PCIII) helped to improve throttle response ?
Old Apr 22, 2006 | 09:59 AM
Anubis's Avatar
Yeah the PC3 will sort it for ya with a custom map, mine did exactly the same thing stock and with the RS5 can. I got a PC3 and custom map made on the dyno, now its gone.. Pulls hard from 2k upwards.
Old Apr 22, 2006 | 12:10 PM
Socrates's Avatar
Thanks Anubis...I think I will get a PC3 and have it mapped....Did you also change the air filter or are you using the stock one ?
Old Apr 22, 2006 | 03:47 PM
Anubis's Avatar
I went down the K&N route yeah, theres a debate whether or not it helps flow more air. But I got it cos it`s re-usable really.
Old Apr 22, 2006 | 06:20 PM
Socrates's Avatar
Cool thanks for the advice Anubis
Old Apr 24, 2006 | 11:11 AM
Anubis's Avatar
No Probs
purpleslug
May 13, 2009 12:19 PM
07ceeberthousand
Feb 28, 2009 06:11 PM
Diablo Runner
Jul 5, 2008 05:00 PM
2002F4!
Jul 13, 2007 05:55 AM
simonp
May 23, 2006 10:25 AM
