Just did the dyno today!
Old Jul 14, 2006 | 08:19 PM
Tblade's Avatar
Default Just did the dyno today!
My only mods so far are Yoshi slip on, k&n and flapper mod. I always put 94 octane as well(now im wondering if I should keep on doing it). The bike made 137.7whp and 70.8 wtq(SAE corrected). Now isnt that a bit low considering most guys make over 150whp stock?
The wheather wasnt perfect but still! It also runs very lean from about 6200rpms to 9400rpms, we are talking around 11.4-11.6.
I will post the dyno page later. The bike has over 1000 miles up to date and seems to be running smooth.
I went back to the dealer where I bought the bike from and they did recommend to get the power commander which I just ordered and should be in within a week or so. Once installed and mapped I will do another dyno and see what happens.
Any thoughts will be greatly appreciated!
Thanks!
Thomas
Old Jul 14, 2006 | 08:33 PM
RR Pilot's Avatar
Default RE: Just did the dyno today!
Sounds like you were on an EC dyno which some debate provides "more accurate' numbers. Whatever.
Sounds low if you were on a Dyno250, especially with a slip-on and free-er flowing filters. Those are usually good for at least 2-3hp up from an average 145rwhp on the 04-05's.
Power Commander will clean up your curve and add a couple more.
Old Jul 15, 2006 | 08:09 PM
13brsxsrr's Avatar
Lots of Variables. I think you have to use the same dyno when you measure power #s of the same machines. Also after only a 1k miles it's still a virgin. The bike depending how you break it in, after about 10K miles will make it's full power on a stock machine. Oil, fuel, air temp, air humidity, elevation, and the way you strap it down to the roller can all effect dyno power #s. Don't feel cheated just put more miles on the bike.
Old Jul 16, 2006 | 09:19 PM
Tblade's Avatar
Thanks guys!
Old Jul 20, 2006 | 01:55 AM
1000RR's Avatar
Just so you know, you are giving up HP on the dyno with that 94 octane fuel.
Use 91 as recommended by Honda.
Run 89 on the dyno for a few more HP.
Lube / adjust your chain
Put 42psi in the rear tire
Full synthetic oil is good for 1.5 - 2.0 HP
Break-in a bit more, that should be another 2-3hp
Power Commander only help if the dyno guys know what they are doing.
Make sure they clamp off the PAIR system, or you're A/F ratio will look alot
leaner then it really is.
You should be able to hit 140 on a good day, with an "avg" calibrated dyno.
FYI: The K&N's could be costing you a few HP as well... maybe try the stock ones
next time?
Old Jul 20, 2006 | 04:02 AM
Tblade's Avatar
Thanks for the advice 1000RR!! The 94 octane costing me power does make sense since I remember even on the 6gen accords(not 7th, they actually gained a few ponies) the 94 octane took away some power and 89 was actually way better.
Thanks and I will try swapping the k&n next time before and after dyno maybe it would help other guys to know for future referrence as well!
Thomas
Old Jul 21, 2006 | 01:37 AM
openclasspro's Avatar
i posted in 1k forum-did mine on mobile dyno last nite-
138.9 hp @11.500
64.91 @10,350
bone stock- 1500 miles-honda hp4 oil-225degrees running temp-89 degrees-44 %humidity-phil
Old Jul 27, 2006 | 10:21 PM
ORIGINAL: Tblade
Thanks!
Thomas
you call 11.4 lean?
Old Jul 28, 2006 | 01:56 PM
MeyekulBayrd's Avatar
A buddy of mine had a 10:1 a/f once with his 900rr. That thing use to throw a little suet out the pipe every now and again.
Old Jul 28, 2006 | 03:54 PM
Tblade's Avatar
At some points on the graph it actually dipped under 11. Hopefully it will be fixed with the pc I just got installed.
skip954
Feb 13, 2009 07:09 AM
SirJAG
Sep 10, 2007 04:11 AM
biker.gal
Mar 25, 2007 12:44 PM
chesthing
Aug 17, 2006 02:02 PM
