internal gear indicator by acumen
Old Oct 1, 2007 | 12:03 PM
browningbuck's Avatar
Default RE: internal gear indicator by acumen
yes it reads two signals...first the rpms, then the speed(whihc is read at the shaft). it takes those two signals and does a simple equation that makes a linear idea of rpm to speed ratio. being that the rpm to speed ratio is different between each gear it then is able to guess what gear you are in while riding. i pick these two signals up inside the gauges (this is why there are no external wires) (except on the yamahas, there rpm signal is all goofy coming out of the ecu so i have to go back to the engine sensor and bring it back... so there is an external wire on the yamahas..... but i havent released those yet)
Old Nov 28, 2007 | 04:47 PM
ahh just thought i would revive this thing from the dead and tell everyone to check out all the new color schemes on these other sites
Old Nov 28, 2007 | 07:36 PM
cbr1000rrick's Avatar
From what I have read, the speed on the CBRsis determined from the rpms and from the gear that the bike is in. If this is correct, there must already be gear indicator in the tranny or something. Why then can't that signal be tapped in to and displayed instead of tapping in to the rpms and the speed to come up with the gear? If there is a gear signal already, why must we go about displaying the gear in a Rube Goldsburg manner? Just something to ponder. [sm=wtf.gif], or I may just be full of s**t, who knows?
Old Nov 29, 2007 | 02:40 AM
Blue Fox's Avatar
Retired Moderator
Does Acumen have a kit that can be installed externally for the people who don't want to take apart their instrument clusters?
Old Nov 29, 2007 | 07:50 AM
tomc1965's Avatar
http://www.gear-indicator.com/
I think that is an external kit.
Old Nov 29, 2007 | 08:21 AM
ORIGINAL: cbr1000rrick
there is no "gear signal" it takes the signal of the RPM and makes a linial equation of the Mph per that gear. being each gear has its own equation it VERY quickly guess what gear its in.
also inorder to hook up the plug and external GI you still have to take the front clip apart to get to the harness so you might as well just send them to me
Old Nov 29, 2007 | 05:06 PM
Blue Fox's Avatar
Retired Moderator
Thanks tom. My internet was bogging down and couldn't look it up. That's probably the one I'll end up going with. No more trying to get into that phantom 7th gear anymore.
Old Dec 1, 2007 | 06:15 PM
Size:  83.7 KBName:  DSC_0024.jpg
Old Dec 1, 2007 | 06:18 PM
Size:  26.2 KBName:  DSC_0240-1.jpg
Size:  66.7 KBName:  DSC_0229.jpg
Old Dec 1, 2007 | 06:21 PM
Size:  51.9 KBName:  IMG_1993.jpg
subyman1440
Nov 15, 2012 09:57 AM
lkngood
Jan 25, 2009 03:07 PM
bladerep
Jun 3, 2008 10:54 AM
browningbuck
Nov 28, 2007 05:00 PM
golfbum69
Jun 30, 2006 03:00 PM
