I installed Power Pilots
Old Jul 7, 2007 | 08:04 PM
oregonjumper's Avatar
Default I installed Power Pilots
Installed new Power Pilots today with the tools shown, less a homemade bead breaker. Balanced them at home and saved a ton. I was quoted 500 from a bike shop and I got 270 into to whole job, well plus some sweat. Anyone have ideas on pressures for the tires.
[IMG]local://upfiles/13231/AB2CFD0D02754401A2A3AEDB508821B6.jpg[/IMG]
Old Jul 7, 2007 | 10:31 PM
baxsom's Avatar
Default RE: I installed on Power Pilots
tire pressure depends on where you ride
street cruising oem pressure is fine
street canyon carving 32/36
track
30/29
at least that is where i put mine at. the michelin rep the last time i did a track day told me that after you come back to the paddock immediatly check your tire pressure, it should be around 5psi over what it was cold. more than 5 means you had too little air
less than 5 meant you had too much
these are the pressure that met those standards
Old Jul 8, 2007 | 12:08 AM
Onarom's Avatar
Good info- Thanks Baxsom. I was running with too much pressure in my tires.
Old Jul 8, 2007 | 01:18 AM
Thanks for the pressure info, that's pretty much what I run. The job was suprisingly easy, just took about 4 hours to do.
[IMG]local://upfiles/13231/C851B3DB8D994EC68FB3797A487DC85A.jpg[/IMG]
Old Jul 8, 2007 | 05:20 AM
dwhite645's Avatar
Default RE: I installed Power Pilots
ORIGINAL: oregonjumper
WTF! [:@]That is a serious rip! Is that including the price of tires? Even so, that's a huge rip!
Dealers around here charge $25 per wheel to mount tires if you bring in the wheel. $50 per tire if you bring the whole bike in. Even tire prices are comparable to online stores.
I think you should throw a brick through their window for being asswipes.
Anyway, good job on the tire swap. Next time will be easier. Are the only special tools the bead breaker and irons? Get any scratches on the wheels or anything? Did you just run a rod through the wheel for balancing? I'd like to do my own at some point.
Old Jul 8, 2007 | 11:58 AM
baxsom's Avatar
i got my pilot powers for 200 bucks mounted at cycle gear
worse case by them from superbike supply and pay someone to mount for you
still cheaper than 500 bucks
Old Jul 8, 2007 | 05:36 PM
I did unfortunatly get a couple small scratchs on the rear wheel. Gonna get some touch up paint this week, any tips on how to avoid this.
Old Jul 8, 2007 | 06:25 PM
baxsom's Avatar
try to find a product called no mar tire tool
i dont know a lot about tires but i know the company name is no mar
supposedly pretty good stuff
buffddy16
May 24, 2011 01:23 PM
paigecm1
Nov 25, 2009 07:33 PM
f3racer
Mar 19, 2009 12:13 PM
sikanimator
Dec 6, 2005 01:42 AM
