Exhaust Install Easier?
Old 04-10-2007, 04:41 PM
Orangebutter's Avatar
Default Exhaust Install Easier?
I was wondering if anyone knows or have done the exhaust on a cbr WITHOUT taking all of the tail section off. In other words just cut the pipe right behind the muffler and then just slip the new muffler on.
Old 04-10-2007, 05:11 PM
Default RE: Exhaust Install Easier?
Nope.
http://www.hardracing.com/CBR1000Exhaust.htm
Old 04-10-2007, 08:02 PM
no you have to take the tail section off there is bolts under it for the muffler. i did mine i put on a hotbodies its easy to do
Old 04-10-2007, 11:22 PM
DWT74's Avatar
The 1000 tail section comes off a whole lot easier than a 600RR tails do, they are shorter. Dont be afraid to bend it (spread) it a little not alot just enough to get the right side to clear the subframe then it will lift right off, dont forget your 4 wires on the left side, hope this helps
Old 04-11-2007, 03:42 AM
I think I will give it a shot instead of having the dealer do another install and taking my leg. I was just curious if you could just cut the pipe just behind the muffler and install with a clamp of some sort. That way if you wanted to switch to another muffler it would be any easier thing to do. And it wouldn't take a few hours just minutes.
motofreak
09-19-2008 05:19 PM
lowlife
04-15-2008 02:15 PM
wsideshow
06-25-2007 08:44 PM
drgonzogoo
05-16-2006 07:48 AM
drgonzogoo
05-11-2006 05:04 PM
Quick Reply: Exhaust Install Easier?
