PC3 USB
Old Apr 10, 2007 | 09:36 PM
Sargeant Shitbag's Avatar
Default PC3 USB
Will the pc3 for the 2006 cbr 1000 fit the 05 model and what is the differance???
Part #'s are diff. 06/07 125-411
04/05 121-411
Old Apr 10, 2007 | 10:02 PM
doncollins's Avatar
Retired Administrator
Default RE: PC3 USB
Will most likely be different plugs and such.
Old Apr 10, 2007 | 10:05 PM
Default RE: PC3 USB
Looks to be same plugs??
Old Apr 10, 2007 | 10:10 PM
doncollins's Avatar
Default RE: PC3 USB
The pins inside the plugs could be different... the brain is the same, so there has to be something different with the wiring. Could be length.
Old Apr 10, 2007 | 10:13 PM
Default RE: PC3 USB
Does anybody know for sure not guessing?
Old Apr 11, 2007 | 11:54 PM
WolfPack's Avatar
Default RE: PC3 USB
not sure about the PCIII, but as far as the bikes go the 06/07 was tweaked motorwise from the 04/05with a higher redline, higher compression ratio among other things if i remeber right.....have you compared the other end of the PCIII harness to see if the injector plugsfit?
id sleep better knowing i had the correct part-number that went with my bike installed in it...
Old Apr 12, 2007 | 12:20 AM
Default RE: PC3 USB
I just found out from Dynojet rep that the pc3for a 1000rr will fit any year both part numbers will work on either bike you just have to load a new map for the correct year bike bc the maps are slightly differant. He didnt see a prob if you didnt, just advised doing it.
Thank you for the help!
