Exhaust Install Easier?
RE: Exhaust Install Easier?
The 1000 tail section comes off a whole lot easier than a 600RR tails do, they are shorter. Dont be afraid to bend it (spread) it a little not alot just enough to get the right side to clear the subframe then it will lift right off, dont forget your 4 wires on the left side, hope this helps
I think I will give it a shot instead of having the dealer do another install and taking my leg. I was just curious if you could just cut the pipe just behind the muffler and install with a clamp of some sort. That way if you wanted to switch to another muffler it would be any easier thing to do. And it wouldn't take a few hours just minutes.
