exhaust
Old Jan 20, 2007 | 03:57 PM
kryptonite_cycle's Avatar
Default exhaust
how the hell do you disconnect the the tailpipe exhaust valve cables and does the servo motor come off also? i am trying to install the yoshi rs 5 on my 06 cbr 1000rr
Old Jan 20, 2007 | 04:03 PM
Certified Ryder's Avatar
Default RE: exhaust
Ask and ye shall receive: http://www.hardracing.com/CBR1000Exhaust.htm
Old Jan 20, 2007 | 08:50 PM
mybikeismybitch's Avatar
Default RE: exhaust
I just did mine last night and the 06 is different than the 05 the plate with two phillips screws on the exhaust is the same but the controller is behind the battery. Take the cables off at the exhaust first then follow them to the controller and there is a couple of screws on top you have to take off to get the cover off and then you can disconnect the cables. Hope this helps, i know i had the same question and all the help pages and the instructions refer to the cables on the left side of the motor, ain't the case with my 06. Let me know how it worked out for you.
Old Jan 20, 2007 | 08:56 PM
rebelle's Avatar
Default RE: exhaust
Hello, I am from France!
I look for information to empty the inside of the exhaust!
Have you a drawing representing the various details composing the exhaust of 1000 rr of 2006?
Old Jan 20, 2007 | 09:19 PM
Default RE: exhaust
Also don't remove the servo motor, you will get the check engine light. Just remove the cables. And the cover comes off at the bottom, i just opened it enough to get a pair of needle nose in and removed the cables.
Old Jan 20, 2007 | 09:48 PM
rebelle's Avatar
Default RE: exhaust
ok, butit is to adapt on the motorcycle which possesses carburettors (xjr 1200) thus I would have wanted to empty in its entirety the exhaust
Old Jan 21, 2007 | 12:26 AM
Default RE: exhaust
yeah i cut the cables by the exhaust heat shield and tomorrow ill follow the cables up by the battery box...guess i have to get behind the box somehow
Old Jan 21, 2007 | 05:18 AM
rebelle's Avatar
Default RE: exhaust
That wants to say " cables ", they are electric cords or it is the other thing, I do not understand? Because if cables is electric, what I search it is to empty the exhaust so that the air is not any more retained
Old Jan 21, 2007 | 10:11 AM
Default RE: exhaust
it's cables! notelec cables
Old Jan 24, 2007 | 02:45 PM
rebelle's Avatar
Default RE: exhaust
ORIGINAL: kryptonite_cycle
I understand the term of cable
thank you
I did not think of finding this system on the exhaust
vanhaman
Aug 15, 2010 06:09 PM
tricksta1984
May 25, 2010 10:20 AM
whiteflash
Feb 4, 2009 07:49 PM
cammelo
Apr 3, 2006 04:02 PM
