Air temp sensor
Old Jul 28, 2008 | 10:45 AM
Fede's Avatar
Default Air temp sensor
Anybody eliminate the air temp sensor (1000rr 06)?The sensor is located on the air filter box
Old Jul 30, 2008 | 07:49 PM
jhellstr's Avatar
Default RE: Air temp sensor
Why would you even consider that? It provides critical input to the ECM to provide the correct air fuel rato. It would most likely revert to a default mode and assume some nominal air temp to keep the engine running reasonably well.
Old Jul 31, 2008 | 06:26 AM
Fede's Avatar
I eliminate the air temp sensor and the sonda lambda sensor(o2 eliminator).I did that because i have PCIII with an own program and without sensors the program is more estable.I have a lcd display for fuel ratio.
Thanks for your answer.
Old Sep 4, 2008 | 02:10 AM
dashle's Avatar
well, where is the sensor located?
Old Sep 12, 2008 | 10:18 PM
TBagr's Avatar
if you did it then why are you asking others if they have. either provide your input or dont bore us with it
Old Sep 12, 2008 | 10:24 PM
dashle's Avatar
so where is it located? i need to get to it and dont feel like digging around for it.[sm=hiya.gif]
Mark Dowsett Bugsy
Dec 19, 2014 03:11 AM
crow1
Mar 27, 2011 02:44 AM
johnnyx
Aug 8, 2010 06:44 PM
Myles
Jun 6, 2009 02:41 AM
rdrink25
Aug 19, 2007 08:11 AM
