advice timing
Old Feb 8, 2007 | 07:29 AM
akes's Avatar
Default advice timing
hi guyz,my bikes motor was completely rebuilt,(bearing knock,1 wheely 2 many),i put in a new crank,falicon knife rods,wiseco 0,5 mm oversize 13.2 com. pistons,head ported,HRC wsb111 cam kit(duration @ 1mm=in :261.6,ex:264.3,in lift:9.4mmx lift:9.0mm)full arata system,pc111 usb,k&n filter,i have ordered an ecu from DAN KYLE(still waitin 4 it)to increase my rev limit 2 13500,now what i need is some advice as to what degree setup i should run 4 da best power,PLS HELP!!!!!!!!!!!!!
Old Feb 9, 2007 | 07:02 AM
blade17fire's Avatar
Default RE: advice timing
U must be some kind of a handyman to rebuilt your engine on your own!! Wow..even thou I can't give any advise..gd luck man!!
ranchome
Feb 22, 2012 06:33 PM
stoneguy1037
Jul 25, 2008 05:37 AM
allenpa5
Aug 16, 2007 02:59 AM
Hindra
May 3, 2007 10:56 PM
ghostrider
Jun 17, 2006 12:05 PM
