Starting issues on 99 F4
Old Jul 11, 2010 | 07:28 AM
cybr600's Avatar
Default Starting issues on 99 F4
On my 99 F4 it does this only once in awhile but I turn the key on, fuel pump primes press the start with the kill switch not engaged and the kickstand down and it doesnt do anything. Battery is good, looked over the wiring and nothing looks lose or damaged. When it does this sometimes I turn the key a few times and it fires right up. There have been times I coulnd't get it going at all, does this sound like an issue with the starter solenoid relay or has anyone encountered a similar problem? When problem is being experienced when the start switch is pushed I hear a very faint click and that's it, doesnt turn over.
Old Jul 11, 2010 | 09:18 PM
justasquid's Avatar
Id suspect the starter relay as well since you hear a faint click. If it was any other switch, pressing the starter button should do nothing at all since those saftey switches would prevent anything from happening.
Next time it happens, find where the relay is and see if you can feel anything in the relay. If you feel a click in the relay, but nothing happens, then its definately the relay that is bad.
Before replacing it though. I would first pull the leads off and make sure they are clean and tight. it sounds like the relay may not be getting full power, so a loose connection somewhere may be the cause. Also, make sure the leads on the other end of the wires are good as well, such as the battery and the starter itself. I would also suggest disconnecting the battery first before doing this so you don't accidentally ground out the hot, or worse, start the bike by jumping the two poles with a wrench.
Old Jul 16, 2010 | 07:42 AM
cybr600's Avatar
thanks for the advice I will try that and see if it helps.
AMSOIL929
Jul 16, 2013 12:14 PM
bburke88
Nov 8, 2012 12:37 PM
graygeezer
Jun 15, 2011 08:47 AM
thegatekeeper14
Jul 11, 2009 02:32 PM
ffry6326
Apr 8, 2007 12:45 PM
