engine ice? vs traditional?
Old May 12, 2010 | 10:15 PM
F4iMane's Avatar
Default engine ice? vs traditional?
What do you guys think? Any drawbacks to using engine ice over traditional coolant? Engine ice is only a few bucks more to go that route so
________
Water Bong
Old May 12, 2010 | 11:05 PM
vangill's Avatar
July 2010 ROTM
i heard its mainly for track use in case it spills its not as slippery, and that thats the only benifit
Old May 12, 2010 | 11:19 PM
F4iMane's Avatar
no that would be something like water wetter. I think engine ice can be slippery. Many have said that it lowered their temps like 10 degrees which is worth it for a few more bucks instead of traditonal. BUT are their any drawbacks. What are the cons of engine ice if any? Or any reasons not to use it??
________
KarinaLYNX
Old May 12, 2010 | 11:29 PM
65ShelbyClone's Avatar
I think the biggest benefit of Engine Ice is that it's much less toxic than regular ethylene glycol. It has diluted propylene glycol instead(Evans coolants are the same stuff with no water). I don't see how it could function noticeably better than the proper blend of diluted EG, but it probably isn't any worse either.
Old May 13, 2010 | 12:17 AM
sxf250c220's Avatar
I am not an expert. That would be a good subject to look up but I am pretty sure in the Motocross scene all the guys we rode with run Engine Ice in there bikes... "lower engine temps"?? in turn "sustained HP"?? True maybe??
randyjoy's Avatar
I have it in my 954, slightly cooler (177 v 182 normal cruising temps). Less toxic if I spill some or overflows and the dog is around. Less slippery if I overflow and someone on a bike runs through it.
Like F4iMaine said, I use Water Watter in the race bike, but some trackday orgs allow Engine Ice (some allow regular antifreeze).
Old May 13, 2010 | 05:49 PM
F4iMane's Avatar
177 vs 182 is a respectible difference I would say
________
Wellbutrin Settlements
lanceam24
F2 Tech
Feb 21, 2011 11:45 AM
knifemaker87
F2 Tech
Sep 17, 2010 09:21 AM
julius1
CBR Zone
Jan 4, 2010 11:32 PM
98formulaLS1
Aug 24, 2009 10:04 AM
Workwell
Jan 14, 2009 10:02 PM
