Starting problem!!!!!!!
Old Sep 9, 2009 | 01:32 PM
Sparkyf2's Avatar
yes, i try with and without
Old Sep 10, 2009 | 08:30 AM
johnnyx's Avatar
Ah, I see. The battery is dying from the cranking. Sounds like you've got a fuel delivery problem, probably from dirty\clogged slow jets. When the bike is warmed, the metal in the jets expands slightly, which may be opening a partially clogged one to allow just enough fuel to pass. This is one of the reasons carbureted bikes run like *** until they're warm.
It could also be a bad pulse generator, which is affected by temprature, though that's way more rare of a failure.
Old Sep 10, 2009 | 10:36 AM
Sparkyf2's Avatar
ok, so i need to pull my carbs and check them out/ clean them and try from there?
Old Sep 10, 2009 | 11:02 AM
johnnyx's Avatar
Yeah, that's the most likely culprit. Make sure you check your airflow stuff while you're in there. Also, pull your plugs out and see what they look like.
Old Sep 10, 2009 | 11:12 AM
Sparkyf2's Avatar
Will do, thanks.
Old Sep 10, 2009 | 02:53 PM
JWade's Avatar
So, i got the bike back to my house a couple days ago, it was quite a long 3 mile walk/push with the bike!!! Here is a pic of the connector to the R/R. Its kinda blurry but its the top corner yellow connector that is fried. I dont know if i just need a new R/R or connector. any suggestions? Do i need to get a new connector? if so where?
Attached Thumbnails Starting problem!!!!!!!-sany0653.jpg   Starting problem!!!!!!!-sany0651.jpg
Old Sep 11, 2009 | 01:26 PM
johnnyx's Avatar
Woof. That's bad news bears.
Your ground wire got fried (common). Also, your battery is most likely fried (will no longer hold a charge). See if you can find a replacement R\R from a late-model R6 or GSXR that comes WITH the connector, so you can just lop off your old one and splice on the new one. That's may be difficult; I lucked out and found mine on ebay like that. If you can't find one, then you're still going to have to dismantle that old connector anyway and somehow connect the old wires to the new R\R.
If you find a solution that allows you to use the same metal female connectors form the wiring harness, then clip the one off the green ground wire, spray it with carb cleaners and clean it with a wire brush, cut about an inch (or more, figure out where the scorching ends) off the wire and re-solder and crimp the connector to it.
Old Sep 11, 2009 | 02:05 PM
johnnyx's Avatar
Here's one I just found that will work. Feel free to surf around, I got mine for about $30:
http://cgi.ebay.com/ebaymotors/ws/eB...94&refid=store
Here's a good walkthrough from Idodirt:
https://cbrforum.com/forum/cbr-600f3-17/my-own-r-r-problem-85851/
I like my method of finding an R\R with the stock cable better, cuz then you can lop your connector off, and splice in the Yamaha one, like I did:
Old Sep 14, 2009 | 04:12 PM
JWade's Avatar
I looked on ebay also, couldnt find the 30 dollar R/R, but found this one. Would this one work, it has the connectors and all.
http://cgi.ebay.com/ebaymotors/07-08...=p4506.c0.m245
Old Sep 29, 2009 | 06:19 PM
JWade's Avatar
Got the new R/R and put it on, running alot better. Thanks for the help.
dirtyhall
Apr 15, 2011 08:41 AM
CBRPutty
Aug 12, 2010 09:04 PM
dgraviett
Jul 14, 2009 10:59 AM
whtan20
Nov 25, 2007 01:36 AM
ITZOBIG
Apr 14, 2007 11:56 AM
