ignition coil 900rr
Old 03-09-2017, 02:47 PM
IgorCbr's Avatar
Default ignition coil 900rr
anyone knows how the wires diagram going to ignition coil for honda 900rr 1996y?
Old 03-10-2017, 04:43 AM
IgorCbr's Avatar
My bike sometimes work on first two cylinders sometimes on 4 cylinder then again on 3 ?
When i dismiss the spark plugs one of them or two are wed ?
What can be the problem ?
Also i have changed new spark plugs,new air filter,new oil and oil filter.
Old 03-11-2017, 09:21 PM
Tony Mawad's Avatar
If you have an intermittent problem, then I don't think it is an electrical as much as a fuel thing (you say that it runs sometimes on 2, 3, or 4).
To find out which cylinder isn't firing, put a wet rag on the exhaust, and the cold exhaust header will be the one that isn't firing.
When something is intermittent, I usually think of gas or carbs.
I think gas goes bad much faster in motorcycles than in cars.
And a 96...that is 21+ years...at this point, maybe the carbs should be cleaned (look into cleaning them or if you should).
Old 03-12-2017, 08:33 AM
IgorCbr's Avatar
Yeap i cleaned them again same thing maybe i need go in workshop and sync my carbs maybe that is happend cuz lot of years and the bike is old never the carbs are synced
wookster
03-02-2011 05:23 PM
wookster
03-02-2011 09:34 AM
Es-f2
09-17-2009 06:41 PM
Guinness
01-31-2006 09:35 PM
C3_954rr
12-11-2005 02:33 PM
Quick Reply: ignition coil 900rr
