2003 won't start
Old 07-27-2009, 12:00 AM
blueferret15's Avatar
Default 2003 won't start
Hi again!
My bike won't start, my guess is that its either the fuel pump or spark plugs because it cranks strong but the engine won't start.... I have no plans on messing with the fuel pump so I want to go for plugs right now.. So I popped the gas tank cover and opened the air box, it has strong smell of gas (Did I drown the engine??).. Anyway, I opened the airbox, but not sure how to remove it to get to the plugs.. Any advise / instructions??
BTW - The bike was fine two nights before, I revved the engine and killed the switch immediately before the RPM goes down.. Does it cause anything?
...Yes I already did a search..
-Mike
Old 07-27-2009, 09:47 AM
isolated1523's Avatar
Retired Super Moderator
When you turn your key on, with the killswitch on, does the fuel pump prime? That's the little whining noise that you hear each time you turn on your battery. If not, you can rule out sparkplugs and concentrate on the pump.
Now that i think about it, i've got over 6,000 mile on my 07 and havent used the killswitch one time lol....
Old 07-27-2009, 09:51 PM
Yup it primes. When I tried to hold one of the hoses inside, and I can feel some movement when it primes so I guess fuel pump works...
Old 07-28-2009, 06:47 AM
Kleetz's Avatar
check you battery. I had this same problem. Everything came on with the key in the "on" position...Fuel pump etc etc and it would just crank til the battery died. I even changed the spark plugs!!! That set me back like 50$-60$ Turns out the battery couldn't hold charge and I replaced it. Starts everytime now.
Good luck
Old 07-28-2009, 10:33 AM
8 blinks on the Malfunction Indicator Light (MIL).. Looks like I have to check the TP Sensor...
Gnarly 928
11-04-2012 10:29 AM
sktr9246
01-29-2012 08:58 PM
itlnF4I
03-09-2011 08:26 AM
touche
09-05-2010 05:33 AM
Kleetz
05-11-2009 05:49 PM
Quick Reply: 2003 won't start
