Paddock Stands
Paddock Stands
Hi folks,
I have asked my son to get me some paddock stands for Christmas and birthday, only 24 days between them and I want a headstock paddock stand for the front.
Does anyone off you kindly people know what size pin is required for our headstock and can anyone recommend a decent well priced make of paddock stands.
There is no rush due to me being on the rig for Christmas and New Year but he wants to get them before I get home.
Thanks in advance.
Thanks in advance.
Not sure about the 1kf, but the 600f has a 24mm. Problem is I couldn't find 24mm pins at a decent price. What I did was use a 17mm socket, which had 24mm OD and a 17mm pin. I just pop the socket on the pin and then use the lift. Stability isn't compromised whatsoever.
Getting a new pin done from solid axel. Most stands sold here comes with a fistful of pieces of metal pipes that you put on top of each other to increase the pin diameter. It's pretty stable that way, I just happened to lose the fittings so I tried ghettoing my way around it
i borrowed one with a 22 pin, fitted ok in my 99f1000 to do the fork seals, it was a made up pin of a lathe though, as the fella lent me it, had a F said it was wedged on the front fairing with the standard one. maybe made the difference. took a wee bit of a help to get it up on, but gave me excellent clearance for the forks to be stripped.
