Not happy with my shifting technique at higher speeds...Pointers?
Old 10-18-2016, 07:12 PM
coalminer frank's Avatar
The key to a smooth shift is "rev matching", whether shifting up OR down. Theoreticcly (nice spelling) a motorcycle dont even need a clutch except for taking off from a dead stop. The transmission and clutch isnt like a car. I never got into clutchless shifting, it wasnt the way I was taught so I always use the clutch. It just seems unnatural not to use it, even though I've read different.
Old 10-19-2016, 08:55 AM
Jaybird180's Avatar
Originally Posted by ozzyAL
Plus 1 for clutchless shift . Load the shift lever , back off slightly and it will fall into gear smoothly.
Loading the lever can result in bent forks. It's best done simultaneously.
Old 11-03-2016, 03:57 PM
mjp94cbr100f's Avatar
Try it ull like it! Just keep the rpms up
Old 12-03-2016, 08:00 AM
pcmaher's Avatar
I've been thinking more about this. I'm assuming that a motorcycle trans is similar to an automotive trans, meaning that there are synchro rings in it. Is this a correct assumption? If so, shifting clutchless could wear the synchros out prematurely. Unless a rider is able to match internal component RPM's nearly perfectly before shifting, synchro rings will wear out.
Now that it's colder, I notice my trans is balking even more. It sometimes doesn't want to upshift into 2nd, and at times it's actually come out of second a few times on it's own. I'm thinking there are some internal issues. Does anyone know if there are trans rebuild kits available? Or, is there a known issue that might be causing this?
Old 12-03-2016, 09:39 AM
Sporty982000's Avatar
Bent shift fork, or bent forks, i do not know of a rebuilt trans kit, tear down, replace damaged parts.
Old 12-03-2016, 01:45 PM
Jaybird180's Avatar
This guy doesn't have the showmanship to make his YouTube a sensation but he explains very well how a motorcycle transmission really works and dispels a few myths.
Old 05-12-2017, 01:07 PM
pcmaher's Avatar
The other day I'm coming home from work, and I'm really having a time with the gear shift lever. 2 blocks from the house I can't get it out of neutral. I finally get in gear and get it home. I put the kick stand down and notice that it is really loose. I stand the bike up again and put pressure on the kick stand with my foot. Sure enough, it is really loose. I carefully lean it on it's stand, open my garage up and bring it in. I put it on my wheel stand and see that the kick stand bolts have loosened and backed out A LOT. So I get my work clothes on and start investigating. The bolts had backed out and were so loose that the kick stand assy was basically dangling. While down there, I took the shifter off and disassembled it. I cleaned the metal bushing inside the foot lever; it was corroded and whatever lube was in there had gummed up into a sticky mess. I also cleaned off the seals and treated them with a rubber lubricant. Put it all together and rotated the arm on the splined shaft assy one tooth CW so that the shift level position moved down just slightly. I've been wanting to do that for some time. The modified position is much more comfortable and effective for my ankle geometry. The clean up and lube, the new position, and tightening made a big difference. There is still a bit too much clearance from wear to my liking, but it has made shifting sooo much better.
Old 05-12-2017, 03:36 PM
Hawkwind2016's Avatar
Good result!
I need to take a look at the shift mechanism on my fireblade, 1-3 is a nice positive change, but 4-6 is a bit 'wooly'.
Anyway, glad you managed to improve things
murtagh
04-26-2008 10:59 PM
atown
09-05-2007 12:13 PM
adi12682
04-15-2007 04:28 AM
simo1000rr
10-29-2006 08:01 PM
Oli@24out
07-09-2006 08:43 AM
Quick Reply: Not happy with my shifting technique at higher speeds...Pointers?
