fluid dilemna
Old 05-04-2016, 08:59 PM
wooferdog's Avatar
Default fluid dilemna
New Spiegler clutch line.
Master cylinder says use DOT4. Line says Type F.
Which one do I use?
Old 05-04-2016, 10:05 PM
74demon's Avatar
Type F? In a hydraulic clutch?
I'd stick with dot 4.
What's in it now?
Old 05-04-2016, 10:50 PM
wooferdog's Avatar
Nothing, at the moment. System drained. Slave and master cylinder rebuilt.
Now the line doesn't say, "Use type F". It only says Type F
Old 05-04-2016, 11:19 PM
74demon's Avatar
That may refer to the type of construction of the line.
I can't imagine using anything other than dot 4, or dot 5.1, in it for fluid.
Old 05-05-2016, 12:11 PM
TimBucTwo's Avatar
Go with the DOT 4.
'Type F' is racing ATF.
Old 05-05-2016, 09:04 PM
wooferdog's Avatar
Ok, Thanks for the replies.
DOT 4 may have been state of the art in 1987. Should I upgrade to a more modern fluid.
One last note. The new slave piston seal would not, by any efforts, fit in the bore. Still using the old piston seal. Will it make difference what fluid choice I make?
Old 05-05-2016, 10:31 PM
74demon's Avatar
Dot 4 will be fine. You could get some higher temp racing dot 4 if you want to, but its probably not going to make a difference other than piece of mind.
As long as that old seal doesn't leak, run it....
Old 05-05-2016, 11:27 PM
wooferdog's Avatar
Got it, Demon thanks.
Thanks, TBT for your input as well.
Much needed.
Old 05-06-2016, 01:03 PM
TimBucTwo's Avatar
I don't see any gain from switching to any type of super-duper wiz-bang fluid. You're only using the fluid to disengage the clutch. Your not gonna take seconds off in the 1/4 mile.
The newer brake fluids hold up to the heat better. You'd have to be shifting in a blurry frenzy to generate the slightest amount of heat, if any at all.
Old 05-06-2016, 04:25 PM
wooferdog's Avatar
I only use my clutch at stops
Is it only me or is there really a video about juicing on your post?
Kuroshio
06-16-2012 08:59 PM
Kuroshio
05-24-2011 02:05 AM
VTcbr
12-15-2008 04:21 PM
johndoe
11-27-2005 10:31 PM
SquireSCA
10-14-2005 02:49 PM
Quick Reply: fluid dilemna
